The Land Rover Appreciation Group.
John Hancock
[quote name=scraggs;1235286
We fixed it by replacing the stock springs with 2+ heavy duty terafirma rears and machining the assister spring plates a bit so the assisters could still be fitted' date=' and then putting extended bump stops on, it never gets anywhere near the bump stops now, but is a bloody uncomfortable ride when empty.[/quote]
HI KIETH if mark you get to the BUMP STOPS THEN THERES 3TON THERE :thumbup1:THANKS JON :thumbup:
Got the egr blanking kit fitted to the 130 cherrypicker last week which for once turned out to be a very strate forward no dramas job, less than an hour.
Not sure if it's made any performance improvement but it seems to stink less when sat ticking over for long periods working the boom, was definitely gummed up inside as paddle was very stiff to turn inside!
Well done on that, glad it went well without any hassle. Should help with fuel I would think. Got mine complete with hoses as yet not fitted, when time allows?
HI JOHN sorry to ask again mate is that TD5 thanks thanks take it to jermy fern to get remaped thanks jon :thumbup:
Yes 57plate td5 in that one jon, don't think there much point in spending too much on performance when it's the sort of vehicle you don't want to be going fast and find a corner because you won't make it!
Plenty of other things to do to it before messing with performance too much.
