  • Replies 48
Look on you tube for electric log splitters.
The ones I've seen have been slow and only suitable for an older person who can't wield an axe.
Yep, had a look far to slow, looks like a new axe is on the cards.
Ta
Hi, ive got the ryobi version and do about 30 cube a year for personal use. i, had it about 5 yr and no problems it is slow but i can stand there all day where as with an ax i was knackered after an hour. it does knotty stuff pretty well and experience soon tells you the best way of loading the log. anything to knotty i chop up with the saw after. i cut all my logs to 18 inch and have split oak and beech rings that have taken two of us to lift onto it. would def recommend one
Chris
You're right mr kipling,not all electric splitters are rubbish,my mates got a clark 5 or 6 ton 3 kilowatt one and i wouldnt say its slow.
He shew me what it would do,and it soon busted up some beech and oak rings.
Hope this helps kev.
I've had this for six years and split an artic load of wood with it every year:
Buy Axminster LS5T 5-ton Electric Hydraulic Log Splitter from Axminster, fast delivery for the UK
It's £198.50 at the moment.
The only fault has been a failed weld on the splitting wedge last year which was repaired by the local shipyard for a few quid.
I process 19" logs with it so there's very little ram travel before the split, if you're doing stuff that's much shorter you need to stick something between the ram and the log to speed things up.
I got a 5t Sealey splitter due to health reasons making me unable to splti with an axe over the last winter. Yes its slower than an axe, but if you cant swing an axe its quicker. Being an acquaintance of the Sealey area manager I got a good price, and with a years warranty itll do me for now. i wouldnt want one to use commercially though.
Chris
Thanks :thumbup1:
Any idea how much you can get done in a day?
Cheers :thumbup1:
I'll have a look later.
Looks like the Scheppach OX T500, but 100 cheaper, is it rebadged by Axminster or a chinky copy I wonder.
Balfor AV5 Looks good, with an exposed external ram, but twice the target price at least. Can be used either horizontal or vertical and has a decent oil capacity.
