Lidl electric chainsaw sharpener.
Bearded Munch
Thursday 26th July Lidl has an electric chainsaw sharpener for £19.99 if you want have a look on their page there is a video of it, myself i prefer the good old files, but for some it may be handy Quote from the description, Suitable for most standard chainsaw chains, including ¼", 3/ 8" and 0.325"
With solid base made from die-cast aluminium
Non-slip clamping screws hold the chain firmly in place
Integrated LED for lighting work area
Adjustable chain guide rail
Adjustable sharpening angle
Low-vibration, low-noise 85 watt motor
Grinding wheel Ø (mm): 104
Retractable grinding head
Mounting materials included
Cable length (m): 1.5
Weight approx. (kg): 2.45
Size (cm): 30.5 x 23.5 x 22.5
3 year manufacturer’s warranty.
  • Replies 35
I bought a couple last time. Been very good for us on the processor. For the money a bargain if I was to criticise it the peg that holds the chain in the right position is plastic but once you master it all fine just got to watch you dont take too much off some teeth. I buy loops of carlton chain cheap so if the grinder is a bit more aggressive than hand sharpen does not bother me. I am ashamed to say it sharpens better than I do by hand.
Just picked one up and will be seeing how I get on sharpening a chain that I last used to slice up some waste kitchen worktop...
I was tempted by one of the 43cc twin handle brush cutters at a penny off a hundred sheets but had the wife with me to keep me in check!
Lidl seem to get some good bits in now and again. The radio ear defenders are good. Tools like the sharpener, they did get some good loppers in once got a few pairs an dthey are still going strong.
Might have to go and get me one today. Do they only come with one disc or can you buy the discs again? Anyone looked to see if other discs will fit on the sharpener?
Yes you can get the wheels all over no probs. I bought one of these machines about a year ago and its served me very well. I have hardly worn the stone and I even dress it up with a diamond every now and then.
