just get an old prussik loop ,slide it on to the spring & pull it up ,worked fine for me in the 6 yrs i had my 125,
Scared of getting your hands dirty Johny?
:001_tt2:
I use a silicone gun to fill the bolt heads with white silicone which saves alot of time picking the crap out.The silicone comes out easily with a pin or similar and prevents the bolts rounding.
That's a great tip - I'm definitely going to try it!
I never bothered locking the tw flywheels when I used to change the blades, the socket used to lock against the flywheel housing and prevent everything spinning around. Definitely lift the roller box out of the way - the prussic technique works very well for stretching awkward springs out of the way. When re-assembling, don't be shy with the copper grease, replace any bolts with any evidence of damage to the heads, and use a torque wrench (do not tighten everything until you fart). Future blade changes should subsequently be a piece of cake!
