Hi
My truck has started to not want to tip when it's got more than half a load of chip in it.
I know nothing about what to do!
Any help would be much appreciated.
Cheers All
There could be a number of things but the primary ones are
Pump is weak (worn) leading to low effort
Or
The return valve is defective, they occasionally stick partially open which means not all the pump pressure gets to the ram leading to low effort.
Don't tip the body and then remove the return valve without properly supporting the body - you'll either end up with a very sore head or otherwise get cut in half. You'll definitely end up with oil everywhere.
