Cone Spacing
Dean Lofthouse
  • Replies 25
If your using traffic control your lead in taper can be at 45°, with the cones 1.2m apart, then the cones down the job Max of 9m apart with a min of 2 used and then a exit taper. If your not using traffic control ie enough room for both lanes of traffic to pass still it depends on the width of your closure to length of taper and number of cones, 31 to 40 mph single carriage way 1m wide 20m taper 4 cones, 2m wide 40m taper 6 cones on so on. All exit tapers 45° and 1.2m spacing.
its a three lane road, which is perfect, just going to close the overtaking lane going uphill starting from where it turns into two lanes at a traffic island so no taper required on that side. Then taper my side downhill into the centre lane, which then tapers back in itself before the island.
The road is an ideal layout really
thanks for that Craig
dean get yr sen a chapter 8 blue book ,:biggrin:
