Mole / field mouse problem ?
Dean Lofthouse
  • Replies 37
Verminator's are illegal to use in the manner that is being suggested as is petrol/gas. They can only legally be used in this country after the tunnels have been cleared to collapse the tunnels. Get yourself some tunnel or scissor traps from Flatpack trap company. Its not as easy as some think to catch regularly but once you know how you can get almost 100% catch rate and should be able to clear a field in a day or 2
By the way
Be very wary of using a mole man- should I say ANY mole man
They have dark arts
£25 a mole
They arrive in a big coat
Walk around your field and bring back a good number of moles- often these have been caught previously and you pay
A customer of mine ended up paying over £1000 to a guy like this until he realised
By the way
They have dark arts
£25 a mole
Some "Tree Surgeon's" also lay tarmac, butcher trees and dump the waste in layby's. Good and bad in all trades including Mole catchers :001_rolleyes:
I never had much luck with scissor traps. I prefer these:
mole trap stainless | eBay
You need to set them in pairs, one each way into the run, and you need to specify UK moles as they're a slightly different size to US ones, but I find they work really well if you follow the instructions and the moles don't bury under them like they do with the scissor ones.
I start by stamping down all the molehills in an area - then wait overnight so I can see which run the mole is currently using.
I then open out a bit of the run, working from a hole until I can clearly see it both directions, put in the traps and then cover over the exposed bit with a piece of paving slab, with earth around the edges to make sure it's dark. This is one of the down sides to the scissor traps - harder to cover effectively.
If you do use the traps in the link, it's worth tying a bit of bright ribbon through the loop at the back. If they get moved around by the mole shoving earth up the mound, or ants move in, you can find the traps without risking your fingers.
Alec
