  • Replies 30
Same as Amsteel or any other dyneema winch line.
2 points to consider though, firstly you can't knot it, so it would have to be terminated onto a portawrap or similar, secondly it has a very low melting point, so controlling the speed of the carriage under load is important.
http://www.forestry.gov.uk/pdf/ODW910.pdf/$FILE/ODW910.pdf
http://www.highlandbirchwoods.co.uk/userfiles/file/publications/Forest%20Research%20Reports/TN694%20log%20chute.pdf
if its a sensitive site what about using a log chute, cheap to set up and they may be able to rent one in for doing it rather than having to purchase a lot of kit for a one off job, they are good on steep sites which it sounds like this may be a suitable technique to use depending on the cutting spec of the timber.
