Im going over my CS30/31 stuff. I remember that the performance difference in chisel and semi chisel cutters is that chisel chains cut more aggressively. Well I think that is right, im sure I will get corrected if its not. But what is the actual physical difference between the two cutters?
Cheers guys answered all my questions in one there :thumbup1:
basically it sounds like full chisel is better but only if you have the ability to control the aggression?
I used the term aggressive and was told not really more aggressive, just faster.
The reason I said aggressive was that's all the trainer had said all week.
Assessor enjoyed hearing faster rather than aggressive.
Sent from my aye phone using Tapatalk
If you are about to take your CS30/31, my tip is to buy a semi chain as a new full chain will jump about a bit when doing letterboxing, whereas the semi will give you much more control. OK I don't do as much as others but I have found it all in saw sharpening technique. I do a large sharpening session with chains finally set not by a gauge but by how well they cut, then do a box full of spare chains (old ones for stumps). So if I'm working and a chain goes blunt, it's just a case of swopping over - ex boy scout:thumbup1:
