How many people use Aspen?
antipesto
Do you;
106 members have voted
  1. 1. Do you;
    • Never use aspen
      67
    • Always use aspen
      24
    • Occasionally use aspen
      15
Aspen Fuel is made from mineral oil production like normal unleaded petrol but has numerous harmfull items taken out/not added. It is not from a natural grown source like rapeseed chain oil.
We asked Jeremy Pilch to start importing this into the UK having been to Norway a long time ago and seen the difference.
  • Replies 98
Question on draining saws - because if you don't use them for a couple of weeks the fuel goes off and you risk seizing the piston and wrecking it.
Question on why pump fuel is an issue - because in a 4-stroke engine you have separate lubrication, so in a car the fuel is effectively all burnt, and the remaining hydrocarbons are picked up in the catalytic converter. In a 2-stroke engine the fuel is also the lubricant. As such, approximately 1/3 of the fuel passes straight out of the exhaust unburnt. Pump unleaded is approximately 2% benzene, so your chainsaw exhaust contains approximately 0.66% benzene. Benzene is a known carcinogen.
Question on how you get exposed to exhaust - the concentration depends on what you're doing - if you're milling, forestry type felling, cutting stumps low or using a hedge trimmer your head is very near the exhaust.
Question on how long the effects take to show up - think of lung cancer - few smokers die in their 20s, not many in their 30s, more in their 40s, a lot in their 50s/60s cf. non-smoking population with a 15-20yr greater life expectancy.
Alec
Thankyou Alec, I was beginning to think I was being snubbed. I though the fuel going off was the issue, but i didnt realise that i could risk seizing the saw! I just thought it may cause an issue starting them. I leave some saws for weeks inbetween using them, never had any probs but definatley something i will think about in the future.
To be honest I had never heard of Aspen until reading about it on here, its something I would definatley like to try, then decide for myself whether its worth the money or not.
Just order direct from aspen, that's what I do, I get 60 lt at a time, delivered to my door. As for price well it's all tax deductible.
No can do, as a freelancer, some weeks I only use 5l or less so I would probably have the leave the remainder in my will.
The building I rent has rules about flammable storage, max 20l so that’s a non starter too.
As this is turning into a general Aspen related questions thread anyway... If I use Aspen4 and mix it with aspen 2-stroke oil, does it keep or does it go off like petrol/two-stroke mix?
There are a few machines I very ocasionally use that need different fuel mixes (1/33 and 1/40). mixing as needed is haslle and wastefull as mixing by the tankfull is not practical.
Some people seem to get away with it for years - others don't. I didn't, and developed a rather expensive barrel and piston habit. There were other factors, but this was one I could eliminate. To be honest, that was the main reason I switched, as you can buy a lot of Aspen for the price of a genuine Stihl pot and piston - the health benefits became apparent when I stopped coming in after a day's milling feeling sick with a bad headache. The fact that the carcinogens have been removed/excluded was a later, and very welcome discovery.
Alec
Also this is my situation. I live in a flat and have no other means of storing the fuel so i have to buy as needed. Some days i go through 5 litres per day and sometimes 5 litres can last more than a week. So apart from my reasons for not needing to use it, i just cant use it because i cant store it.
As for the health issues, I stay in the auld reekie and i smoke! whats for me wont go by me. I will die of something that is sure:001_rolleyes:
It should be a thread to raise awareness of the health risks associated with the machinery and fuel we all use on a daily basis.
There is loads of evidence and scientific studies to confirm what should be obvious to anyone that works in the industry.
Have you ever held a hedgecutter at head height for eight hours in a day, cut big stumps with a beast of a saw, reduced leylandii hedges on a still cold, damp day? The fumes hang around and soak into your clothes and every pore in you skin.
It may be convenient to ignore the issue. At the end of the day it's our livelihoods.
What doesn't kill you makes you stronger. Or does it just kill you later? Maybe not. Maybe you are not genetically pre-disposed to certain diseases. Maybe you are. How do you know? Do you care?
3-Dost-PowersawEmissions.pdf
Professional Users - A case for Aspen.pdf
