so what are they then? I have seen the above pliers on you tube work for exactly these clips. as far as I am aware that is why there are different head, ie for the ones with a hole in, but I'm no expert so will be grateful for your advice
Pic of Circlip
Iv not seen the vid you have but you normally use a small flat blade screwdriver to prise E clips off and needle nose pliers to pop a "NEW" one back on . Use E clips "once only" as there pre stressed. Those E clips look to be from Dolmar saws...you will lose them off the saw more often if you strain the clip putting it on or re using after removing it.
Edited by Sawchip
cheers. I thought I was fecking the clip up removing it with a screwdriver (I  was) but didn't know they were single use so thought I needed this tool to do it properly. thanks
Using a tool to open the clip to instal is not going to do the E clip any good as it should just spring into place in the groove on the shaft. Removing is never the issue as you then use a new one.
Soz Westy, took dog out, made tea, blah blah blah!
As above really, but i disagree about E clips only being used once then throw away, i think a lot just depends on the application.
They're pingf*kits but if I caught them I used them again.
