You can check the resistance but this isn't conclusive as the trigger electronics can go bad.
I usually make sure the gap between the flywheel and coil is correct, make sure the HT cable is good with a multimeter and if you still have no spark - with the cut out wire taken off, then junk it!
Ta :thumbup1:
How does the HT lead come off at each end? Bike ones used to unscrew but do saw ones do the same?
Found some non gen coils on ebay for £20 are they worth bothering with or are they a bit naff?
Ta :thumbup1:
The newer Husky coils have the HT lead potted in to the coil - I measure the resistance between the cut out connection and the ht inner cover where the plug electrode fits - it should give a reading of a few ohms.
In life you get what you pay for, I would look out for a genuine second hand one. Many are interchangeable - 346, 357, 345, 350 etc
Ta :thumbup1:
Finished repairing my washing machine at midnight last night, it kept blowing fuses, had already stripped the motor which has now had around 6 sets of brushes on it so knew that was OK.
The heating element was at 20 Ohms (OK) but that was the most likely cause. Ordered a new sort of replacement" off ebay - had this washer for around 17 years now:001_rolleyes:
Fitted the new element and no hot water - fab, stripped the back off again, ran it up, metered the connections and got 240V, reconnected the element connections and bingo, one working machine with the element working again - original was showing signs of leakage between the heating element and the outer case hence it blowing fuses!
Hope the thing carries on for a bit now and perhaps I can get the MS200T on my bench ready to sell:thumbup:
Anyone help?
The 24 and 26 share the same side cover, others share side casings but the part numbers for the 24/26 don't match the 066.
What are you looking for and I may be able to help what works with what!
Wanting a 2nd hand one for an 034 :) so wondered what other models fitted
Right - the part you need is 1125 640 1701 and the side cover off the 024/026 will fit and are listed as the same part, the MS240 and MS260 will also.
The 028, 038, 044, 046 are also listed with the same number and probably a few others will also fit.
Hope this helps, looks like it will be easy enough to find one
