This is what has happened to 4d5df1b3810381102da93d5a968b51af.jpg84847e3acc095b5dd9f344054359da51.jpg1564dbc3b2392f4a8cc0c9db4a784258.jpg
Sent from my LG-H850 using Tapatalk
If the scores are actually through the plating then it is scrap. If the damage is aluminium transferred on to the cylinder then it can be removed.
I had similar and had to fit the Chinese top end due to the cost of the OEM part. Wasn't that impressed with the cylinder but for a homeowner it would be a good machine!
Im to have a go at cleaning it up I've already got a piston knocking around somewhere. Then new gaskets and it should be good might give it a lil muff mod as I do love to upset the neighbors 😂.If I have to fit a am cylinder I have found some German ones I'm willing to try out.
Been given a good running stihl ms361, was hoping to change the quick release/quick tension adjust to a standard side casing and standard chain adjuster but unfortunately the inside casing is slightly different and there is nowhere for the chain adjuster to fit :(. Will still be perfect for a slightly bigger groundsaw when I get it back together. ImageUploadedByArbtalk1485370174.300012.jpg.f9cfe2cd4e48ef775319b149a54f8349.jpg
Husky 395 xp. My Pal recently got one so i decided to take it apart for inspection and clean , new crank seals fitted although nothing wrong , crank bearings smooth , new fuel line and filter installed , carb was mint , air filter had a little split in the mesh at the join so new one fitted , couple of scuffs on the piston but cyl was perfect , new meteor piston fitted , wee buff up with scotchbrite on a flapwheel so the new rings will bed in , back together now and been run blocking up an Elm along with my 395 xp which has 58mm cyl/piston and mild porting and a baffle free side exit muffler, mine is the one with the 28 inch Powermatch logo on it , his has a Powermatch bar too but logo worn off , but in the other pic you'll see the 2 new bars we got , 37 inch Powermatch RW bar and a 37 inch Tsumura bar
Other pic is my 562 xp with new wrap handle and outer spike , but will get the big spikes soon the mail from Stubby , just for the looks really :thumbup1:
Edited by huskywilson
Can anyone help with a guide bar bolt that has lost its hold thread gone in saw body . do I heli coil or is there some type of resin etc that is strong enough to hold the bolt in on a stihl ms 210 thanks
I think that the standard collar screw is part no. 1123 664 2400.
It might be worth trying the oversize D9/M8 collar screw for the MS231etc. That's part no. 1123 664 2405.
Collar Screw/Stud D9/M8 for Stihl MS231, MS231C - 1123 664 2405 | Other Stihl Spares
