Have you got a different one from the one I sold you? :001_rolleyes::001_tt2:
Haha, no complaints about that saw, have 3 old saws but that's the one I use all the time, cutting its way through 25t of larch atm, no probs apart from perished fuel line, newer not always better!!
Ano newer not better but I'm just a tube haha:biggrin:
Arms are like Popeyes trying to start that thing today:thumbdown: all my tools are in work😞 need to wait till Monday
Ano but wasn't getting used because it was just a little noisy :blushing:
I will getting it going then sell it and get a 241 or a 550
The ported 346XP isn't that noisy TBH, just sounds a little more angry than standard
My other saws at max revs you could still here the 346 ticking over hahaha and my girlfriend heard if from about 1 and a half away 😂😂 and thought I would share the love of a ported saw..... A member from here bought it :biggrin:
Well they got a nice job and well running saw:thumbup:
No rest for the wicked, been working on a Stihl 020AVT - yup, one of those antique ones:001_rolleyes::lol:
Got the saw stripped down, the internals looked like one of those muddy patches on a football field but a good blasting with the compressor and copious amounts of spray sorted it.
I am converting it to run on Motomix so new fuel lines and carb kit, the recoil was not recoiling and it is now:thumbup: The flywheel pawl pins are missing big pieces off the top and this would cause catastrophic failure in a short period of time.
The pins are not available so will fabricate something that will work - probably thread the holes and use thread locked bolts!
Done a number of 357XP rebuilds recently and each one has had a deformed impulse line connector on the inlet manifold. This damage is caused by it not being located on to the cylinder properly.
Personally I usually fit the rubber manifold and then fit the plastic parts afterwards - it normally avoids this sort of damage!
All of the machines were leaking air from this issue:thumbdown:
I had summit a bit different yesterday. A new chonda (Chinese Honda copy lol) engine that was brand new but had been smacked or dropped either during shipping or at the importers causing a 2mm split in the engine block/base and distorting 1 of the engine mountings!
I was going to get hold of another block and rebuild it but then thought i had nothing to lose experimenting...
Aluminium braze rods wouldn't flow due to the heat sink distubution of the block, just couldn't get it hot enough.
Next throw in some 90/10 alloy/silca wire and screw a bottle of argon on the mig and seems to have done the job well visually so today is a case of running it up and checking for oil leaks. Cast alloy is a bit of a b*gger welding as although it looks good it can go porous with oxidisation and heat despite cleaning it well and grinding the edges up.
I would love to add a tig welder to the collection but keep putting it off as its like buying an ms880/3120 just to use a few times a year having money tied up in something that doesn't pay its way unless used a lot....
Edited by wisecobandit
