  • Replies 41
Brilliant! I don't think you need to worry about the centre joint, it looks as beefy as anything on a Weidemann or similar.
Did you just weld the loader frame straight onto the chassis?
I'm off to look at cheap dumpers and orphaned loaders on flea bay!
Excellent - can't think of a good reason not to have one!
Are the rams from the loader,or are they the original tilt rams?
Looks really good,expect the cost of second hand dumpers to go up even higher now:001_huh:
I like that :thumbup1:. If you could shorten the arms on the loader you may not need so much counter balance. Because the loader is closer to the ground if you dont need the height and can see the forks may be an improvement.
it's welded to the chassis i was going to make it removable but when i sat it on it just looked right and i decided that was it
rams came with the loader and are alot bigger than the dumper rams
have thought about moving front axle as far forward as possible which would bring about the same result
Would help but may increase your turnng circle. I use 4x4 to shunt trailers around yard lwb trooper a nightmare Daiahatsu fourtrack ideal.
Mount a towball to the front bumper. Makes such a difference to workrate.:thumbup1:
