Just have a think about how much Brush you process.If you regulary have "Tail Backs" of stacked Brush piling up behind a working 6inch machine,then you need higher processing abilitly,or if your guys keep pace with a working 6 inch machine then it might not be for you.
BruIn my opinion a 9inch machine processes sh twice as fast or faster than a 6inch.
No, get away, really?
  • Replies 32
[/b]
man there was no need for that sort of comment,
they say sarcasm is the lowest form of wit
I am tempted to go bigger..
Pressumably there is a greater demand for sub 750kg chippers so you get greater depreciation on big machines. So if your buying second hand you get better value on the big chippers. I guess big machines are on top of the job more often so less thrashed..?
bigger chipper = less snedding, the cm220 likes big branches
I must admit its a pain in the arse going back to a 5-6" chipper after using the bandit 90 which is either a 9 or 10" :D
but who i work for at the moment isn't bothered about the logs.... just get in there and get the job done as they take on a lot in a day :)
