Mini charcoal retort - Mk2
If your anywhere near Bolton I could let you have a couple of barrels with lids.
Cheers John, Don't get out that way much but if it looks like I will be I'll let you know :thumbup1:
Very cool, good effort!
I read something on the 'net from a chap who was insulating his retort or oil drum to keep things even more efficient....
Cheers :thumbup1:
Insulation is one of the things I'd liek to incorporate but don't know what would be easiest to use. Wondered about that exhaust packing stuff?
  • 1 year later...
  • Replies 24
Looks good. I was at CAT yesterday and they have a home made retort. Have you seen it?
The CAT one is an oil drum inside a big metal tank. But they have a pipe for the wood gas to escape and feed into the fire.
Does yours have any way for the gas to escape?
Customer of mine was explaining to me a way of doing that, pretty sure he said he had built one himself reckoned it was more efficent as a heat source and cleaner and leaves charcoal as a useable by product rather than having ash with a log burner, can't remember all the exact details he lost me as he gets very technical :blushing::001_cool:
0.22 shows the installation used on this retort, looks like he's simply cut it to shape and then held it in place with a metal sheet.
Cheers Nick - wonder what it is though,was kind of hoping that someone was going to say Celotex would be fine!
It looks to me very much like rockwool slab. Given that when I bought it the sideplate of my Rayburn had been hot enough to crack it but the insulation was still fine it should hold up for this job I would have thought.
Alec
  • 1 year later...
To resurrect an older thread. Was any advancement made with anyones charcoal making? I hope to have ago this year whilst working in the woods. I plan on doing a bit of blacksmithing. Therefore would like to burn brash to cook charcoal. Retort style. I also plan on using an airline from compressor to a homemade old brakedrum forge.
I also have many other dreams yet to realise:001_rolleyes: I will post if I get that far.
Also are you still after barrels with lids Chris? If I come across any.
