I want a small machine to run alongside the Tajfun filling the same bag with large and small cord appeals to me i reckon you could do a cube every 4 mins with both machines.
why not have a circular saw machine for smaller stuff?
because i like a chainsaw i can keep sharp myself been there done it i can see the advantages. I would have another farm in a hart beat if they ran them on chain oil
Surely it would be pretty easy to modify.
Or change to vegy hydraulic oil, may need to change some seals.
Yes i had thought of this on my last farmi it would be quite simple to rig up but I'm hearing a lot of people saying the same thing so think it will be a matter of time before they change it. If they don't then ill find another little processor
Even by changing to vegy oil will not solve the heat problem as the hotter the machine gets the oil becomes super runny.
needs an oiler cooler fitting,
Hi mike what fastest pro out there that does 450)500mm cord thanks Jon
The fastest is the pinosa followed by a mutitec imo never used either but seen both up close well been operated.
Tajfun are bringing out a 500mm from what I've been told its going to blow the competition out the water
Hi mike how much do think it will cost and will have one at the ARB show on demo thanks Jon
You getting a processor then jon don't forget its not just the machine there is 100 k of cord your going to need to feed it 10 grands worth of bag/boxs log deck tele
