[attach]185809[/attach][attach]185810[/attach][attach]185811[/attach][attach]185812[/attach][attach]185813[/attach][attach]185814[/attach][attach]185816[/attach][attach]185817[/attach]
That's a really versatile set up you've got there Stephen. Fair play mate.
We still haven't got round to mounting the chipper on the front of ours yet. And the Shute is still too long... We just bought a bigger shovel to clean up with. :)
Hi Stephen what the tractor in this pics a mf135)165 thanks nice pics Jon
  • 3 months later...
So I've finally joined the unimog club. Just got to give it a bit of work, chip box, a rear seal and full service. But the 10t hiab was the deal maker for me as I plan to get a low loader trailer to take kit to site on it too.
Anyway this is before I've done anything. ImageUploadedByArbtalk1444760019.781573.jpg.9033187fd4e2e0cb45ed1e16c3af6ee8.jpg
Anyway this is before I've done anything. [ATTACH]191472[/ATTACH]
10 tons? That s a hell of a lift for a crane that size ime, you sure?
its not a U1000, so it could be a U1200, or a U1500, ( narrow axles and mudgaurds give it away), so 7.5t GVW, so as long as it agg registered, a 10t trailer will be no problem.
I'm with mendiplogs on the crane size though, king post and first arm suggest arround a max of 3t lift, maybe a bit less depending on how its piped, ( most cranes run a wp of around 300bar, the mogs own systen is 200bar, so you loose a third of your lift capability, unless your running a dedicated pump system, usually a pump driven off the back of the gearbox input shaft, check your data sheet for N16) it is possible to get the origonal build spec for every mog built from the chassis no, Ian at a quick guess, I'd say your one starts 424
