stalled Unimog
snatchblock
Hi,
I managed to start my U1000 this morning, ran sweetly. Unfortunately it has frozen in place, (I'm based in Norway, truck is surrounded by 5 ft snow, and we have had -17 for a few weeks now).
I let it run for about half an hour, so all warmed up. Then started to rock in back and forth to break out. I managed to stall it, and now it I can't get it started again. Any ideas?
No leaks, nothing broken, just no reaction to turning the key?
Any help appreciated?
Thanks,
  • Replies 23
Hi,
Thanks,
do you get any lights on the dash or just nothing
Thanks for all of those suggestions, Battery is fully loaded, still firmly connected. It was running fine until I stalled it. Now when I turn the key I get the battery light on the dash, gauges work, lights work. But no reaction to the key. Its almost as if the clutch security switch is not making, ( clutch needs to be fully depressed in order to turn over) but why would that be after I stalled it?
Any ideas welcomed. Unfortunately there is a good 4 ft of snow surrounding it at the moment, and current temp is -12. Looking forwards to spring!
PTO Is engaged, was running the crane on the back whilst waiting for the battery to charge. Checked the button, it depresses all the way, and the truck had been running, (until I stalled it 8() It's driving me nuts!, plus its a long slog through the snow to keep trying things!
Any suggestions very welcome, or does anyone want to come and collect the Bxx**Y thing!
So no start circuit…………………….
First thing I would look at is the start wire on the starter motor. Check it’s still attached to the terminal.
If that’s still on take it off and put a test lamp on it then try the key, if the lamp lights the problem is with the starter, if it won’t light follow the circuit back to the lock out switch and the key testing all the way till you get a live.
I hesitate to mention this but I am assuming you have checked the fuse?
Andy
As stated, start with the easy stuff, fuse?, bypass the switch under the clutch, remove-clean-replace battery terminals, ditto cables to starter, look at back of ign switch.
Can you turn the engine by hand?
Any clicking noises from starter at all?
