  6scotty6 said:
Jas p wilsons in Dalbeatie will do a 350 brand new for that with the feeder, was down in October and watched it go , great piece of kit if your serious about firewood.also the hydraulic holding log arm is excellent for twisted poor shape logs
Cheers scott
just looked at this thread after watching the video of the 350 on wilsons web site , looks like a great piece of kit ! maybe next year !!
i got a trans saw 350 from fuel wood with deck cut 20 boxes one day 30m3 great saw with circular blade no chain oil and cut over 100 ton so far same blade no sharpening
and hydro arm for holding logs down is brilliant
  abrahamthorpe said:
Hi John been looking for a posch - s350 with a log deck
where have you seen one for £22000 is that used? I have found some but they are more expensive then that.
Thanks Abraham
At the Arb show Wilsons was pricing the demoed model which was a 350 wuith a shortish deck at 22-23K + VAT..
Anyone buying one I would suggest they have a good play with one first, a friend has one and had advised that you cant drop in oversize rings for splitting due to a steel bridge above the splitter. This can also cause log jams.
A
Interesting to hear peoples replies on the s-350, looked the best processor around when i saw one working at the arb show.
Alycidon, I rekon you must be able to modify it to put in bigger rings for splitting?
if you can fit the rings in the trough they will split im thinking they would need ripped in half for weight if nothing else
Agreed but we all sometimes stick bigger rings in and slice lumps off the bottom to save setting a splitter up.
I suspect that the Palax 90 is better but I suspect its a lot more expensive.
A
Read more
