Lads,
Im looking at getting a new wagon.:thumbup:
Im keen on a Hilux or Landrover, however I know they cant carry chips and log in massive quantities such a a transit, canter ect.
Im not big enough and cant sensibly afford to invest in a transit and chipper, as well as running my own personnal car.
Basically, I'm after a 4 x 4 , to use as a works wagon for smally jobs and personal use. Also with a 4 x 4 I can get a trailer on tow bar, this opens a few doors.
Is there such a vehicle??:001_huh:
Cheers lads, hope al well.
Regards
Larry,
been a hilux fan for the past 15 or so years got a 2002 i always marine ply back and have 4 metal brackets fixed to the four corners for greedy boards can remove in 30 seconds also have a hinged ply section that slides down back of truck window between geedy boards and lid that lips on to top of greedy boards also have a platform section that fits across top of greedy boards great for the hedge cutting jobs all removable in seconds
I can carry shed loads of chip in my 110 defender, and a 130 will take even more. There is no comparison between toyota and land rover though- they are totally different machines.
When you say personal use, do you mean family use or distance driving? I own a 130 landie for tree work but it is no good as a family vehicle due to only 2 seats, 20ish mpg and being as uncomfortable as you like!! You will also find landies expensive to buy (compared to transits) so for the same sort of money you could run a family car and a transit.
Well Larry if you can find the ideal do it all vehicle you could probably retire now.
Hilux = nice to drive, reliable, fairly economical (compared to a landy anyway). Also, more or less bullet proof and pretty good off road. But, it won't tow like a landy or hold anywhere near as much as a 130 or hicap 110. If you need a crewcab you will also lose most of the back.
Landrover = Not so reliable (although mine has been great). The 300tdi isn't as thirsty as you would think with a few modifications and I have found it to be a great engine. It will tow almost anything. You're unlikely to get pulled by vosa on weight since your GTW is around 7t. As a day to day car... not good. Noisy, cold in winter, hot in summer. I haven't seen one yet that is water tight. On a long journey it's exhausting. I have a real soft spot for my 130 ambulance, but I'm changing to a 4x4 sprinter and flatbed truck, probably a transit or daily.
Well that's my experience. If anyone has that magic all rounder let me know.
