Doesnt look anywhere near 40" across:sneaky2:
Dont get into a habit of cutting buttresses off as one day you may need the wider hinge:thumbup1:
You still got another couple to scrutinise?
more like 20.1 inch or something lol just niped it off so i could cut it all from one side, as i didnt want to be moveing behind the tree on the steep banking. only had good place to stand on one side.
good point about not getting into that habit though :thumbup1:
the other fells werent worth taking pics off as were alot smaller.
I've got into a habit of doing high gobs. Leaving a stump I then need to cut off. From doing site clearance and being asked to leave 50cm stumps for diggers to get hold of. It's ok for small stuff but when it's a bigger tree it's awkward to slice off because it want to sit down and pinch my saw. Although wedges to help
Man with high stump has sharp chain!
Unless I'm felling for timber, I prefer a higher gob as well. Above the buttresses, unless you need the additional hold.
Good call with the single bar sweep with only one decent exit route Rob.
stop halfway through and stick a twig or two in yer cut:thumbup: get them in right and you can use them as rollers instead of lifting it off, helps when you are chogging down big rings..
Having to do only one cut is better. As there's no pause between cutting incase it's a bit of a nasty wind or if the tree is rotten. Your only stopping when you hit the hinge. Not when you have to go round the other side and finish it off.
  • 1 month later...
