Cheers Paul. 😎
As for you other two critics, you are so predictable!🌳
All will be revealed tomorrow. Remember, sometimes "what the customer wants" and all that!
As much a question but why did you bore the hinge when you have as biger bar as that?
So it hinged easier😎
I think one of the lads took a vid of it going over, I'll see if I can get it off him. It's unlikely it would of fallen on its own if the hinge was full width. Hope that explains. 👍
He didn't mean to. He was clearly using a smaller bar for the face cut, and over cut the centre of the hinge with the nose.
Bloody poor work IMO.
Bit of a mismatch on the bore cut height, but tidy Pete.
A couple of 12ft chunks I had to pull with the loader - just shy of 3ft diameter, ImageUploadedByArbtalk1456257969.635339.jpg.319e0d6ffbd961c2a59927141290031b.jpgso the groundies heard my full range of vocab as I hauled the 660 up there !
It's simply a Yorkshire thing, we all do it that way😎
Bit of a mismatch on the bore cut height, but tidy Pete !
In what way Pete? I did the bore at the height of the base of the gob and back cut slightly higher. Would you cut differently?
P.S, nice heap of firewood!😜
