Want to get something like this, (MAN 453 6x6) are these as good as it gets or are there other better alternatives, looking for something with excellent axle articulation, and low range / diff-locks etc, over 300hp. Looking to mount a 20 inch Morbark on the back with timber crane
Edited by David Riding
  • Replies 22
6X6 is great in a straight line.But a Turd to try and turn with even just the rear Diffs locked.
A Chipper on the back would not be much of a load for it.But personally why not tow the chipper with a fast Tractor?
Most of the gear like that I have seen working or used,had to drive on and only on the Chip that was produced.Otherwise much stuckness would insue.
Also if you bog somthing like that down to the Axels,you need alot to budge it.
