  • Replies 235
Tobias, the tree was in Stocksund, kaptanvägen i think the road was, dont know the insurance company but derek might
Peter, the tree motions ok, its a bit of getting used too something diffrent but only been felling with it, need to move the caritools and use that string stuff which came with it. havent done any prunes in it yet which is where i think it will shine. really liking the imori rope now its bedding in. type As comming next week thank god! beaty swallox more like monsoon, 33c again today :thumbup:
cheerd david and tommy, and mark, i thought youd like thisone, even a blind man would be able to see a bits come off:001_tongue:
Does need a bit of tweaking to get it right, but once you have it set up I think you will like it.
Have you tried the lower side dees on spikes yet?
lower side D's?? guessing the darker green loops where the bridge ties in? i havent but will definatly, its definatly a comfy harness, after nearly 3 years of my old one its going to take a bit of time to adjust to something new! liking youre tip on the caritools either side for the saws by the way:thumbup1: although 90% of the time im still using just the left one, and the right is for whoopie sling and pully when chunking down, handy little things!
The lower dees are so comfy when your standing on a pole on spikes, no hip crushing at all. My only problem is that it tends to slip down a bit, especially with a 660 hanging on it.
I have 3 wiregate biners on there for odds and ends of gear, they are great because they lie flat against the harness and dont get caught on branches and stuff.
cool, i'll try them out tommorrow, cheers for that! any other tips? i havent yet experienced it crushing my hips like others and my collegues have mentioned, that may be because i like the back support on harnesses very low compared to most, below the belt line typically.
yeah i did find it slips down a little, especially if i diddnt put the lanyard ring back on the caritool, or rest the lanyard in the caritool, and just had it hanging off the red ring. thats the one fault ive found so far-i cant easily tighten the harness whilst sitting in it, the treemagic í could just pull tight when hanging bigger saws off it
its illegal to hang anything bigger than a 46 on your harness Peter:biggrin:
i enjoy a knackered screwgate krab on the back of my harness for hanging the pole pruner from an old chain from a pto guard:thumbup:
I never knew that!! Cheers!!:thumbup1:
Read more
