hi was just wondering what side/work positioning strop/lanyards setups you guys use.
was thinking of using a longer one with a rope bag and wanted to get some feed back about the ones you lot use
cheers
wiz
my current:
  • Replies 53
normal - 4m length, micro pulley with mini vt knot thing and an isc two way snap :thumbup1:
chogging down - wire core, prussic (must get a rope grab!)
long - 10m with vt/pulley
Edited by alex_m
I normally use a 3m comet wirecore, its soft and really nice, I do have a 7m one in hivee, but tbh unless the tree is huge I find it a pain. Its very rare I feel the need for a second anchor further away than 1.5m. Try a longer one... but I'll bet you don't like it.:001_smile:
i use a 5M yale fire with a grigri which i find good as it can be let out slowly rather than the total release you seem to get with the grab
depends what you want it for if you just need a second climbing line rope of any length is good i have a 10M as well which is great if your in a big wide tree also if you just have a little tree to do
if you want it for blocking down then you need a wire core which is a totaly different thing IMO:confused1:
