There is always a cut off point between the type of ag you choose to use . ( this told to me from a farmer ) and mostely it depends on how much you think the end price of the crop is going to be . If you think its going to make £200/ton ( malting barley ) then its more profitable to plough , make a seed bed and drill  as the yeald will be at the max .  If it only makes £120/ton then its more profitable to just run a " scratchit " drill over the stubble . The yeald will be less than the former method but you will save on time and fuel as less use of tractor . Its a gamble .
Edited by Stubby
7 hours ago, Mark Bolam said:
Utter crap.
Farmers spend a lot of money trying to get new herbs to grow and the field always want to revert back. Mate up the road has run the maths on it, yeah sure he was getting more bales with inputs but the inputs, when costed along with his time, didn't stack up.
On 17/01/2026 at 15:12, BruceWayne said:
Need some advice for liming soil for tree planting.
I am going to plant 2 year old trees in soil which is a bit acidic. I was thinking of mixing lime with the soil used for filling up holes when planting. Or will it a better option to spread lime around the land as a whole ?
Both. I remember people planting truffle trees talk about liming and they just link to this RHS article: https://www.rhs.org.uk/soil-composts-mulches/lime-liming
It may be worth talking to a local agricultural merchant and see if they recommend anything. Round here I have noticed crushed seashell used by some farmers and a bit of googling shows some of the coarser material may last a few years before needing to be redone.
Was he smoking the herbs?
You should be looking at at least a 4-1 return on investment on grass.
It’s not magic, like.
You can’t grow pineapples.
Quite rough ground here. We have herbal leys that have needed re sowing, they were great but only last 5 years then some of the dominant grasses have taken over. So have to redo it. Well we have attempted to stitch in what has gone over time. Will see in the spring how successful that has been.
23 minutes ago, Mark Bolam said:
Not in fields they weren’t.
I know. They were damned ingenious with their pits and greenhouses though.
