Hi all been given aload of cut down timber that i wish to use for firewood next winter or winter after, it will be kept in a barn to keep dry its all been cut up in to smalll sections my question is am i better off leaveing it as a unsplit log or split them to season quicker/better?
some pictures attatched if that helpsIMG_1624.thumb.jpeg.9c2122e4b4512697c3abeece89956b25.jpegIMG_1626.thumb.jpeg.382c6bfc34a9a2077f08a5840c52068c.jpeg
many thanks
Yes, another vote for splitting now.
I'll add to stubby.... driving rain off certainly, airflow is more important but if it is stacked, only the top couple of logs will be affected by normal rain, the rest will keep drying if you cannot get it under cover. Even today after this weekends storms the lower parts of my log stacks are surface dry.
Perfect thanks on that note i have a couple of piles that have been on our land for around 3 years im in the process of splittling that now for use in the home, if these logs do get wet how log do they genuinely take to dry and be good use in the fire?
thanks
Only the surface of the log will be wet if the thing has been fully seasoned in the past and the only way the log will get completely wet again is to leave it in a bucket of water. Rain will just cause the surface to get wet and a week or two inside will dry it again.
Best get a moisture meter, even a cheap one will give you useful information. 20% and under is ready to burn.
thanks
Species dependent really, plus if there’s a through draft etc.
many thanks
That will keep you going for a couple of weeks in the coming winters. :D
Also depends on the log.  A large diameter but short log will dry faster than a long small log as the wood dries much faster from the end grain than through the bark.  This is also why you should cut into logs and split early, the wood will dry faster.
  • Like 6
