Too long out of the game, what is the best throwline on the market right now?
Also does anyone have experience of this throwline cube? Looks nice, if a bit pricey. Don't mind spending the money if its well built and lasts better than a normal cube.
SKYLANDEQUIPMENT.COM
The NOTCH popbox is a spring loaded box to hold your throw lines and bags. Built with durable materials and an easy-loading design, the NOTCH Popbox ensures your gear is secure and...
Anyway I use a pop up laundry basket from poundland, works well enough. I did buy a somewhat more durable pop up garden bag to replace it, but I havent thrown since..
I'm shite at throwing.
I'd like to get or make a compressed air powered potato cannon style launcher, or even propane powered launcher, but I am unsure on the legalities of making such a cannon.
The NOTCH popbox is a spring loaded box to hold your throw lines and bags. Built with...
Can't go wrong with Falteimer mate, mines outlasted every other one I've owned.
I've got one of the circular courant ones too which is decent as it doesn't fold up and twist your throwline.
I'm using Zing-it which has been my preferred line to date and just the cheap notch bags in a few different weights.
9 hours ago, Mark Bolam said:
I’d go Faltheimer cube for half the price Steve
Two Faltheimer cubes. You definitely need at least 2 line and 3 or 4 bags for when the bastard things get stuck.
I am using Petzle Airglide.  Seems ok once you get the reel memory out of the line.
Falteimer cubes for me.  All others seem to be inferior and not very well constructed.
The corners always seem to tear or end up twisting somehow and then making the cubes harder to open.
Not tried the one in the picture but I have had my falteimers for over 10 years and they operate better than some of the brand new Stein and Notch knockoffs.
I found the circular ones to be more of a pain.. unless they are stored and transported flat, and not dropped they seem to tangle more.
Presumably because the lines aren't folded and pinched like the cubes.
Much better in the wind though, they don't need pegging down to stop them blowing over.
Also petzl airline, mainly as its good and sold in 60m lengths which is frequently needed
Falteimer cubes are the only cube brand worth handing money over for. They outlast the stein, weavers etc by many years
Edited by Ledburyjosh
