11 hours ago, Mark Bolam said:
That looks ideal for fatties who are trying to get their steps up.
Not very pc Mark, but very true
23 hours ago, scbk said:
Looks quite heavy duty, but doesn't look very ergonomic to use.
I saw one in use, they had 1 lad operating the controls, and another lad loading logs and putting his hands in by the wedge!
waiting for him to bang his head on the handle when it was in the vertical position
On 30/11/2025 at 10:02, Tree monkey 1682 said:
All small log splitters will leek or weep oil- often they dont have a big enough hydraulic oil tank or no hydraulic oil cooler,  problem with them getting over worked,
Im dubious about ifor trailers due to a local dealership now saying they've been brought out by the chinese and them not stocking ifor because of this.
So in essence what im saying is you might be replacing it with more over priced chinese junk.
I dont know who id recommend in the way of machines seens the are alot stopped by eu legislation or brexit importing to the UK .
I think that's just BS; the sold to Chinese Co bit.
Welcome to.think what you'd like , but why do you think it doesn't happen then? After oil gets squeezed and compressed it gets hot , with no way to cool down, same happens in diggers .
Would you drive a car for a 100 miles without coolant or a radiator?
That is true of a compressible fluid like a gas but oil is not very compressible which is why it is good for transmitting power in a hydraulic circuit. It's the friction in the pipes and squeezing through all the gaps in pumps and motors that make it hot.
We had two crapuchi diggers that cooked rams, two log splitter that weeped oil-using it to much . The only think thats ever survived  continually being used is machines fitted with a hydraulic oil cooler , stops rams, valve blocks and o rings from weeping
As you wish.
Yes oil does get hot and may require oil coolers but the way it gets hot is as I explained. My tractor based grapple loader ran from 1983 to present with no oil cooler because the duty cycle coupled with a well sized reservoir meant the oil never got above blood temperature.
I built a power pack a few years ago to run log splitters, it has a 60litre tank and runs 15/30 suto. I was worried oil getting hot so I fitted a cheap hot water pipe thermostat and cable tied it to ram to keep an eye on it runs at around 40-50 deg c depends how hot day is.
