Tw230 diesel Timberwolf Ford chipper 2017 were is the speed sensor no images any were on the internet
hi everybody I have a 2017 diesel Timberwolf to For Chipper I cannot for the life of me find the speed sensor where is it? Please put a picture on here. I cannot find a picture on Google on images on the full entire Internet no one seems to have one.
Speak to timberwolf / entec uk for exploded diagrams
9 minutes ago, Mick Dempsey said:
Just had a look at mine and buggered if I can find it!
The W terminal ( I think) on the alternator sends a stream of pulses to the control box, because the size of the pulleys are known the relationship of the rate of pulses to the rpm of the flywheel is fixed and the control box can stop (and slightly reverse??) the feed if the flywheel slows.
RDS used to make a box that cut the fuel to the injector pump if the engine overheated or lost oil pressure, is this included in modern ECUs @Jase hutch?
27 minutes ago, John sue said:
I've downloaded all the online stuff can't find any were
As has been discussed, the box of tricks takes a feed from the alternator to know it's speed probably by sensing the alternator amperage.
Probably best checking for loose connections, but if the chipper is charging the battery the stress control box would be my initial guess and or the feed switches and emergency stops.
Granted, last Kubota one I repaired had a black sensor next to the flywheel on the starter side of the engine and used SP4 shown in the diagrams.
Edited by GarethM
Hi there yes iv checked all the switches in both infeed and reverse buttons
checked the relays
checked for loose wires
checked the full loom for damaged wires
and crimped the relay connectors tighter
i have check the stop switch on the red safety bar
checked the plug under the hopper and all looks good
the only thing that I can think to try now is changed the alternator
or check the wires on that but it charges the battery lovely no issues
I hope it’s not the h box as I feel that’s gonna be exspensive
every thing works except the feed won’t stay on
Just seeing if any one on here found any other way of solving there a pretty popular chipper so I carnt be the only one that’s had this problem 😢
