What do you use or recommend?
Most arb ladders I've seen or used , have been past their best and I'd like to get my own for the odd hedge job I might get to do on my own - so Im after a decent one that can be used as an A frame.
Transport will be by car roof rack, so I will be limited in length.
Henchman or similar tripod with all three legs adjustable. 8ft goes up to 9 1/2ft and covers most of our domestic work. But I have 6ft and 14ft as well. Toying with 16ft but not sure I can justify for once or twice a year
Gun to head, one set to do everything? 10’?
8, 10, 12 here, I'm toying with getting a 6ft, and if it's higher than 12, I want a  mewp! 😂
Just spotted Jack P suggesting a B&Q one, this has it's uses, it's handy to have, but it's not the answer to everything.
Edited by Peter 1955
7 minutes ago, Mark Bolam said:
That’s what I’m leaning towards Alex.
The 10ft is the one I use most, I'd have to say.
just going to add not really a fan of any tripods only use them if have to . usually forced into bad working positions often with long reach trimmer not enough space to swing it  against the ladder frame that gets annoying  and feet seem to take a lot of strain on bigger jobs partly I think because of the wrong angle .only issue with ladders like mentioned is not so good for very uneven ground
I’d disagree with that Jack.
My Little Giants extend to about 12’ fully extended and feel sketchy as hell ‘sideways’ if you see what I mean.
They’re heavy as hell as well.
Tripods always seem more stable to me.
How tall are the odd hedge jobs you might get generally? and how tall a ladder are you comfortable using? That's going to help with suggestions I reckon.
I'll be in a similar position later in the year - small fruit tree pruning so interested to see what is suggested.
