Chain Bar "Dressing" tool. Is this necessary and used by professionals?
18 hours ago, Muddy42 said:
I've never used one.  I generally clean the bar first in soapy water.  Then I use a flat file to take off any burs, then I have a good look for squareness with a mini set square and flatness with a piece of aluminium. I also use a magnetic spirit level on the bar, knowing my vice and workbench are perfectly level. I bang dings with a hammer. Finally once flat, I remove the tracks in the rails where the teeth run.
With respect, a little torpedo level on the bar on the bench won’t tell you shit. It’ll make you feel good but that’s about it.
Steel straight edge is what you need. A peice of aluminium is liable to be bent from the off unless it’s an extruded profile.
Nothing wrong with the item described by OP but as Steve B points out maybe not a great file ...
I have yet to meet a human with a eye good enough to give the correct angle with just a flat file on a worn bar, however an old method was to use flat file with two bits of lets say 2"by1" which would show up any real bad left or right inclination. So draw the file supported on said 2x1s with thumbs back towards you and pretty good results. Not so mad using angle grinder with flap wheel with very gentle force.
As for the "don't bother since the rails are splayed", if you are really stuck I have for years put a .063 chain in badly worn .058 bar for the likes of brashing and even felling
Do you not have a guide bar roller tool for squishing the rails back together. A tool I've only ever seen and don't have myself.
No I don't have the roller re set which you could buy from Stihl as a dealer part years ago and as I said if you are stuck or for just brashing a bigger gauge will get you out of trouble.
I saw the set in a dealer friends workshop and was told it was of little use  ?
Yes I know what you mean.  I also use a flat edge, or both together, the flat edge and the digital spirit level, because its magnetic.
Im fastidious about getting the depth gauge for each cutter right, for me this gives a chain which cuts straight and bars don't wear unevenly,  so just need a bit of cleaning up the wear ridge now and then.
Just hold the flat file across the bar with fingertip in the centre to show any lean, drawfile to clean up.
