If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
mike2736
Hey everyone,
I have a large walnut tree that has grown quite massive, and I’m worried that it might split where it forks due to the weight of the branches. I’ve already installed a cable to brace the main limbs, but I’m unsure if that’s enough or if I should remove some weight by cutting parts of the tree. Would it be better to just prune dead branches and low-hanging ones instead?
One issue I’ve noticed is that the fork of the tree tends to collect water and dead leaves. Over the summer, I cleaned out the area and removed dead bark, where a lot of bugs were gathering. I’m wondering if this makes the tree more vulnerable or if it’s something I just need to maintain regularly.
I have some photos showing the tree’s structure from different seasons if that helps. I live in Europe, and unfortunately, there aren’t any arborist specialists in my area, so I need to handle this myself. I do have experience pruning and caring for fruit trees, but nothing this big.
Any advice on the safest approach and long-term health of the tree would be greatly appreciated. Thanks in advance!
Edited by mike27367 answers to this question
Register a new accountSign in
