I have trimmed a reasonable amount of ivy, usually with chainsaw. Two partial cuts and then hit the middle, the lump will ping off with no damage to bark and no risk to chain.
ย
A friend has a brick wall garage, lots of inch thick ivy. It occurs to me I have not tried my 3 blade brush cutter attachement yet.ย  (Used plenty of trimmers). I'll likely do it with chainsaw as it works and its quick, atleast the higher up stuff.
Is a brush cutter blade any good for ivy along the base of the wall? I realise it would need a lot of care, but as I said, not used it before. Good excuse to try a new tool or a bad idea?
ย
Thanks.
What's the goal? To remove the ivy without damaging either the wall or your tools, or to remove the ivy in the quickest possible time, tools and bricks be damned?
ย
Unless the wall is several hundred metres long, secateurs, loppers, and a paint scraper at shoulder height, then peeling down as Mick says before snipping the base; then peeling above shoulder height if it isn't too grippy, or leaving it to die before easily pulling down in one long mat.
ย
Your tools though, and not my wall, so do what you think best!
ย
Edit:
I spent a week in early April 2019 peeling ivy from a Victorian walled kitchen garden in a run-down stately home. 100 yards each wall, four walls, inside and out. 730m, by my maths. Only partial coverage thank god, a lot of still-bare brickwork, but some good thick patches that had really worked their way in there. It was great weather the whole week, and a very relaxing experience. Cathartic.
Edited by peds
Yeah, peeling ivy is definitely cathartic, but can be tedious also. A solid week of it is epic. The elation that results from a big sheet of it being removed cleanly in one go is one of those things that only those who have done a lot of tedious ivy peeling will appreciate! Shame about the irritating dust, makes me cough like a good'un.
ย
ย
A small crowbar can be a useful addition to the tool kit, saves muntering your silky/lopers/secateur if push comes to shove.
A flat bladed spade . shove it up as far asย  you can then grab the bottom and pull and sometimes it comes off in a big sheet .ย
Edited by Stubby
Yes the dust is the worst part, esp if it hasn't rained for ages, should wear a mask really....
ย
Anyone got recommendations for what type mask etc?
ย
A "Big mutt" can beย  useful.
ย
ย
WWW.TOOLSTATION.COM
Ideal for heavy duty applications such as floor tile removal. 1370mm hardwood handle. 177mm blade width.
ย
ย
ย
ย
ย
ย
ย
WWW.TOOLSTATION.COM
ย
ย
ย
ย
Yeah I had to resort to wearing a mask when doing a lot of it. It was giving me chest pain. I wonder if it might be teeny tiny hairs that some people are susceptible to. I don't think it matters what kind of mask, as long as it fits properly. A disposable dust mask, ffp2 type thing.
Yes that normally works well.
ย
I had aย  job i had awhile back where theย  15ftย  walled garden hadย  over a foot of soil formed on itsย  topย  with the addition of a row of cotonaster growing thereย  with theย  ivy inย  the loose rumble masonary infill. It was acting like a massive 100ft long raised planter.....
ย
So Ivy was growing down ย  from the top plus up from the base of the wall
ย
ย
ย
ย
ย
ย
ย
ย
ย
ย
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
