While killing time waiting to pick up the misses from her weekly shopping trip I popped into the local Lidl and they have a Chinese copy of the Canadian wood burner twin fan for £30, either that or it was a Welsh drone 😳
Note: one fan, 2 fans, large fans, small fans.  Ultimately they are all powered from the same thing (never seen on with two of the power sources - peltiers?) so provide the same amount of power to the fans.  I.e. 2 fans is not equal to twice as much air...
Expand
I have 2x paired fans , so 4 turning . Definitely pushes out for than one .
  On 11/01/2025 at 10:52, Steven P said:
Does it struggle to light if the flu is warm? On an industrial coal boiler we had to put a brazier under the chimney to get the draft going, a day later with a warm chimney (not hot day 2) the draft would pull sheets of paper into the fire.... an extreme example but does it light better with a warm chimney?
Expand
No its fine when the flu is warm or used the day before. I've also adjusted the stove a bit to help with the through flow or air - smaller vermiculite chimney baffle to help expel the exhaust and open up the air intakes with a dremel.
Yes I've used an electric heater before to heat an open fire flu.  However I then fixed that flue permanently by reducing the size of the fire opening with a glass strip.
Expand
I'd need to check but might be that with 1 fan the peltier isn't working flat out as it were, 2 fans and it will still work OK (you get different qualities and efficiencies - different power out, plus 2 fans might mean the cold side is cooler (more air), bigger temperature difference, more power out, too much for a simple internet search to tell me)
Expand
I'm not a chimney expert but making the chimney smaller and expecting it to expel more gasses seams counter intuitive (I assume smaller baffle = smaller diameter hole in it?). Might be put a small fire in - a few sheets of paper while you go out to get the firewood and kindling in - to pre-warm a cold chimney as it were - before making the main fire helps? Or a add taller chimney.
Expand
Sorry I mean the opposite.  My stove has a rectangular vermiculite baffle in its roof.  Originally this baffle was of a size that left about a half inch wide gap for smoke to exit.  I had some spare vermiculite board lying around so I made a smaller rectangle to give a bigger gap. All experimental and totally reversible.  The flue has a 5 inch x 7 m liner fitted so plenty long enough.  Yes what I do is lay the fire normally then put some rolled up newspaper on top to provide a flare up.  People talk about 'bottom-up" or top down fire lighting - this is the best of both!
Don't worry I've tried all the tricks - this eco design stove is just a bit sh!t compered to my other older stoves.
Is the space between the liner and the brickwork filled with vermiculite?.
Just thinking it's touching the brickwork and taking all the heat away
Read more
