Hi all,
We all know chain oil takes an age to fill a saw in winter because of the cold but can you recommend any that fit Stihl cans that will make things a little quicker, I’ve seen a Husky spout for winter but does it fit a Stihl can and is it any good, maybe you just do away with spouts and pour straight from the can?
Thanks✌️
9 minutes ago, Al Duffill said:
Hi all,
Thanks✌️
Switch to Supertac veg oil for the Winter.
As per 5th, switch to a thinner oil of you feel it's a bit slow to pour, other than just using it without the spout.
Not sure if eco/veg oils are any thinner than standard 30 chain oil tho.
Stihl synth oil was always a bit like water in summer so presumably it's thinner than 30.
Edited by GarethM
45 minutes ago, Al Duffill said:
Hi all,
Thanks✌️
This one works well but is fragile.
It fits the Stihl Combi can
WWW.LSENGINEERS.CO.UK
Spout with Cap for Stihl Combination Fuel/Oil Canister Genuine Stihl part OEM No. 0000 881 0128
A husky dealer recommended not using bio chain oils unless strictly necessary as they reckoned they gum up on the bar when used irregularly. So I’d guess they’re potentially thicker?
They eventually oxidise, which is the way old fashioned oil paints dry, so they start out thin then go gummy.
Think it's more they dry out, or however you wish to describe it. It plasticised so must be a reaction with oxygen.
I've used veg oil on timber and it's becomes like a sticky clear chewing gum.
Edited by GarethM
