I didn't get on with rotatech bar oil (and I have posted here about it).  It caused my bar sprockets to seize up which has been quite expensive to resolve.
If you are still keen I'll give you a good price for the 17 odd litres I have left?
I was using super sexy chain oil  then when that ran out I bought gator chain oil off Ebay. Cheap as chips and does the job.  Think was 38.00 plus vat ish per 25ltr drum. I just order 100ltr a time so always have it
Derail -
Used both Gator ET30 and Rye Oil. Liked the Gator more as is definitely a sticky (non flingy) oil.
Buying direct from website I seemed to remember was cheaper. As 25l from their site and same price for 20l on ebay.
3 minutes ago, woody paul said:
Go's like treacle in cold weather.
Yep. Never found it much of a problem. Oil tank is ally on the 261 and gets a bit of residual heat from engine/exhaust. Thought that helped.
Not had any issues with it here so far :)
