I am after a diesel generator (preferably Kubota). Almost certainly new. Any recommendations and contacts? Anybody got any experience of the Hyundai diesel generators? Need 6-8kva. Needed for back up, not constant running. If there is a better subject to put this on, please direct me.
Thanks in advance.
Ash1
Stephill SSD10000S was my choice.
10kva s a little more than your 6-8 but a bit too much is way better than not quite enough.
British design and made but has a Kubota engine. Mine is on a pallet but you can get a trailer for more money.
Came off Hampshire generators who are very helpful with info plus good service and I have used them a couple of times now.
They sell Hyundai but steered me to the Stephill as a much better make.
More out of curiosity, what you planning on running from it.
As that sort of size indicates space heaters and maybe cookers these days?.
Edited by GarethM
The Stephill SSD10000S is £7-7.5k depending on single or 3 phase, they are 3000rpm.
It is usually quite a jump in price for a 1500rpm model of similar quality.
I do have a 6kva 1500rpm generator but it is about the same age as me. Only cost £1500. That one is a diesel Petter engined thing and tbh if it is enough power I would suggest looking for one. Very cheap very reliable power that will outlive you if looked after.
Many thanks to everyone who has replied. The generators purpose is a back up in these difficult times and we live quite remotely and we already get power cuts now.
The Stephill is a really good quality machine but I didn't really want to spend £7,500 for it to sit in a shed, in case we get a power cut. Presumably the one that has got the lighting tower could be of interest but it looks like it has 10,000 hours from what I can see which is quite a lot but all your comments are very much appreciated and I thank you.
I would go down the Lister Petter route if that is your aim.
Plenty out there with a lot of life in them and well proven. A Startomatic would be ideal, just kicks in when the power goes out and off again when it comes back on, subject to a changeover switch etc being installed.
I live in suburbia where power cuts seldom happen, so no recent remote experience but I would be looking at a hybrid inverter and 10kWh battery for about £3k. The thing is this can power a house and cope with varying loads you can add a cheap generator that can then charge the battery at constant power for a long outage, switching off when the battery is full. Ideally I would use a 48V DC telecoms genset.
Forty years ago when we ran a remote class room with a 10kVA petter genset the efficiency was appallingly low because the median load was below 2kW yet the engine had to keep spinning at 1500rpm.
Some good advice here, I pulled on an encampment in Derbyshire that had this sort of set up last summer, 4 units working off it if everyone was careful.
