A situation has arisen where I'll be leaving my trailers and GreenMech demo units hopefully in a compound at the top of the village. While it is gated and has cameras, I'd still want to cover my ass with a hitch cover and wheel clamp/security. Any recommendations going forwards?
16 minutes ago, monkeybusiness said:
Lincmaster make some good gear - I adapted one of their hitch locks after an attempt was made to cut it off. Just don’t walk into it in the dark….image.thumb.jpg.1c89316b4ae83cd94f9bbf3f1880c942.jpg
Don't bother locking the trailer, just leave a few of them lying around the yard in the dark :w00t:
Temporary or permanent? Wheel clamps seem to get cut off easily, I've got one on but also a 19mm chain down to ground anchor that's under the trailer so harder to interfere with.
Lorry park. Not bothered if it is permanent until I retire tbh. Just need to stop parking over the road from neighbours as they got the hump!
Second the Lincmaster recommendation, nice to have replaceable locking barrels  and key'd a like, I found hitch locks and wheel clamps from them less hassle to fit compared to bulldog. As per Dan  I used 19mm Almax chain round the axle and through a V pipe in reinforced concrete if you don't mind scrabbling about a bit.
I'll have a look at those, I'd like something better for my trailer too. I have a bulldog heavy wheel clamp for my defender, and it is a bastard to put on and off to be honest. 6mm steel so reckon it has to take a bit of cutting.
Some good 'go to' security tips. I'll use a ball hitch cover and some kind of wheel clamp if the storage thing comes off.
