So to any of you that do decking I have a deck to refurbish and I can mill Cedar decking boards but all the decking boards sold in like T P they all have grooves down them is this needed is it better to have them what do you all think
 Cheers. Mark
I'd say that they're needed. I think their main function is to reduce the slipperyness in the wet. I speak from experience of installing a few deckings plus almost going arse-over-tit a few times on people's decks, that have been down a few years. Algae tends to build up on the surface of the wood to make it extra slippery.
You can get special coatings that contain sand to increase friction, they help but probably wouldn't remove the need for the grooves I'd guess.
I've seen them installed both ways, but was always told grooves down allows better surface area to keep the timber dry and prevent warping as the flat surface is usually sealed/painted etc.
Edited by GarethM
Most decking is outrageously dangerous (slippery). Crasser than astroturf. From a liability point of view, I'd sooner install nuclear power stations.
Edited by AHPP
 I wouldn't bother as it just seems a place to retain water longer and dirt, making  it harder to clean etc.... Also non grooved decks looks alot more classy & expensive & bespoke.
 Grooving while it might help abit with regards to grip  doesn't seem to do that much as they are still like an ice rink if they get green.
Local council have miles of B&Q type board walks. They have all have had "sand paper" anti slip treads retro fitted. Some boards have broken in under 5 yrs from new  but maybe   cedar would last alot longer the cheapo stuff?
Personally I don't think decking is that well suited to the UK climate especially the Welsh one, unless you don't mind  doing a pressure wash & re- oiling regular.
But the climate  here means it wants to revert to a  "celtic rainforest" everthing goes green very fast. SE UK is abit different.
Maybe sho shugi ban is the answer?
Rate in order of crassness;-
Patio Heaters
AstroTurf
Hot Tubs
Decking
Plus, decking makes a lovely cosy space for rats to make their nests. And slugs.
Patio Heaters
AstroTurf
Hot Tubs
Decking
Crass
Decking
Astro
Patio heater
Hot tub
Tolerable
