7 minutes ago, peds said:
I forget in what context you brought up volcanoes and forest fires, so this isn't necessarily directed at you, I just remember seeing someone mention them a few pages back.
WWW.CLIMATE.GOV
Human activities emit 60 or more times the amount of carbon dioxide released by volcanoes each year.
Regarding volcanoes, they are abdrop in the bucket compared to human output.
Regarding forest fires, despite them being an essential regenerative process for various ecosystems all over the planet, they are of course getting bigger, more destructive, and more widespread as a result of climate change - hotter temperatures, longer droughts, etc. - and hitting areas that have not evolved to accommodate them; on top of the inevitable release of CO2, of which I'm not sure how the "natural" forest fires stack up against the "unnatural" ones, plus the regular human emissions. That'd be some interesting data to find.
You've got it all mixed up boyo. The increase in forest fires that we're seeing is nothing to do with Climate Change, it's just because of all those pesky arsonists. (Well, that's what I read on here anyway, in relation to the fires in Greece last year).
Well yes it is as it is the slight change in conditions that allows the fires to take off, for whatever way they are started. The world as we knew it was a miracle of circumstances that made it just right.
Oh right, I remember. Probably either Antifa or Greenpeace arsonists, generally.
2 hours ago, Steven P said:
Depends what you are asking for, the cheapest (least efficient) are half the price of the most efficient, ranging from about £800 / kwh to £1500 / kwh.
Because you say kwh, I presume you are just referring to the cost of batteries? I was trying to look at the total cost - PV panels, inverter and batteries.  Granted every installation is different - mine are on a shed rather than my house which makes the installation simpler, but requires a longer cable.  My only stipulation was I didn't want a tesla battery because I think Elon is a pr1ck.
1 hour ago, openspaceman said:
Bear in mind it was a price for parts to DIY and roof mounting adds to the cost, I bought scaffold poles and mounted on them for my recent 1800W
15 410 Canadian Solar  @£78
3 Pylontech 3000c @£975
1 5kWsunsink ecco offgrid/grid inverter @£1,049
=£5144
Ah so the fact its DIY will explains the reduced cost, nice 1.
Yes, my Daughter's mcs installed similar system with a Zappi ev charger came in at £12k 11 months ago. Professional installation has the advantage of reclaiming VAT and allows you to get an export tariff.
Ah, knew I'd seen the pearl of wisdom somewhere.
I had the PV installed last year and am currently looking at battery systems from Giv energy or My energy.  Yes I am procrastinating about the cost (dropping VAT has helped) but its also quite hard to size the system properly because Octopus havn't installed a smart meter yet (grrr!).
Professionally installed with battery sufficient for storing a winter day's worth of electricity worked out at £2k/kW for her, she is in a particularly good position for Solar PV and produces about 50% more than my similarly sized (4kW original and 1800W DIY addition) in the year. If I were buying again I would have a bigger battery to cover my worst day's demand. I don't see much point going bigger than that because off peak charging covers you for dull days. What is interesting to me is that her Solis hybrid inverter does not allow her to charge to a set % state of charge. The reason this is desirable is that you need to enter the day with enough room in the battery to absorb any solar PV but still have enough to cover the evening demand until the next offpeak slot if it is a dull day.
The economics if you have an EV are something like:-
Peak rate 31p/kWh
Offpeak rate 9p/kWh
Battery amortisation say 7p/kWh
Charge-discharge loses 20%
So using the battery to avoid peak rate costs 9p/.8+7p=18.75p so a saving of 12.25p/kWh by using battery to avoid peak rates.
...and what has this to do with wood burning stoves being banned?
