Sounds like it's getting fuel, maybe not enough but I'd also ask if your letting the glow plugs heat up and turn off first.
Even on the 3 pot Kubota they like a little heat to help them start especially when cold.
Edited by GarethM
I would try taking the key switched wire off the starter motor (small wire with a spade connector) and go through the start procedure and when you turn the key to the crank position there should be a single click when the fuel solenoid pulls in ?
It won't crank with the wire disconnected so you can hear what's happening with the solenoid.
If you hear a 'fluttering' noise then the hold circuit is at fault  , either the feed to the solenoid or the solenoid itself.
4 minutes ago, Mike Hill said:
Have you tried pushing it down a hill then dropping the clutch in second gear?
Noo, it's down and hill over a cliff whilst burning.
But it has to to done on video whilst extolling the virtues of Greenmech and Jase might give you a discount!.
