What's the engine?.
Start simple, air filter then fuel filter and if the pipe to the injector pump is getting fuel.
Without knowing the type of engine, does it have a solenoid pump for the fuel as without that ticking away it won't start ?.
Edited by GarethM
If your completely lost post a pic of both sides of the engine and someone will draw on it what to try.
first follow fuel line from tank to filter. Does the filter have fuel?
Is so doesn’t the line from filter to engine have fuel?
If yes does the injection pump?
Then on to injectors?
If fuel to injection pump but not to injectors has fuel shut off switch got power to it?
Has it got an engine overheating protection system fitted, that might need re setting?
If you've used the chipper for a prolonged period in this hot weather it may have been enough to trigger it
