Are there any corded electric chainsaws capable of milling up to 20" planks. Would ripping chains and bars be an issue sourcing?
Reason I'm asking. I occasionally take a stem from a job back to the yard and would like to reduce noise levels milling it.
Not a chance unless you go to 3 phase.
No. For a 20 inch plank, you need approx a 28 inch bar (to accommodate the mill and allow for corners and absolute minimum 70cc chainsaw, ideally more. There is no electric corded equivalent.
1 minute ago, Puffingbilly413 said:
They do a corded saw but it's designed to run on their F2 mills - it's not a standalone saw in its own right.
Ah yes, would do the job though at the yard. Never going to run off a 13A plug though as that's the power of a 261.
I have 3 phase, but not logosol mill, just alaskan. Not going to try rigging something up, for the amount I mill. Neighbours will just have to put up with the 660 running full tilt occasionally.  I'm sure they hate me anyway!
I would not fancy a 70cc saw milling with a 28"bar. 92cc struggles as it is sometimes on harder wood.
i agree, 120 cc is even better! But what matters for the OP is simply that the required horse power is way beyond electric.
