If I billet up some 12" Ash cut down last September will it loose much moisture by March (to be stored in side shed)??
cessna
I know the above is impossible to give an answer to as so many things to influence how  much moisture a 4" x4"x 36"  approx size    wood billet will loose in such short time. The  shed is a fully enclosed shed approx 60 x 40 ,  humidity   this time of year hovers around 90 / 95 %(hygrometer in shed), so I guess wood ain't  going to dry very much at all. 🙄🙄
Edited by cessna
Might do . Depends on ambient conditions during this time and storage  conditions . If you keep the wet off but allow the wind through it then yep it could loose some moisture but enough is indeterminate as you suggest .
Edited by Stubby
Yes they will lose some  but doubtful it will be enough even with  decent air flow. It's the summer months  May to October when most drying takes place.@cessna why not weigh a billet mark it and pull it out to weigh again in a month, as long as you keep rain off it.
