Could you please advise me......what type of Silky saw would be best to use as I have permission to saw some dead wood in a copse, but am not allowed to use a chainsaw in there because of health and safety rules.  Couldn't use a bow saw as a lot of branches and wood on top of each other,  so thinking a Silky saw would be best to use to get in between the branches. Sizes to be cut..... from 3 to 6 inches then left with the trunk which I can cut with a bow saw once the branches are out of the way.
 (Thought of buying a STIHL mini chainsaw GT A 26..... or a Seesii Mini Chainsaw  8 INCH......  any thoughts or advice much appreciated)
Just now, Retired Climber said:
Ive always used the Ibuki. It's a little longer than the longest Zubat, and would easily do what you need. I've only ever had the old one though, the new ones are in a red scabbard.
Fair comment. I had one once but found it a bit too big for up a tree, on the ground would be a different matter though
Don't bother with a bowsaw, the hardpoint silkys are absolutely superb, the Zubat as Steve says is good, It cuts mostly on the pull and the curved blade is made for the job.
A decent axe will send out quicker than a silky but will have a higher our lay cost.
If your on a budget the Stihl turbo hand saw cuts quicker but won’t last as long as a silky
Yep, agree, Zubat for climbing. However, for the OP, the Ibuki is the winner, imo. It's hard to describe, but for a job for which you'd really rather be using a chainsaw, the Ibuki slogs through a bit better. It's something to do with the way the end of the handle bends round a little more I think. It's almost as if you can push it further away, and then pull it back with your stronger fingers, rather than hold the handle more traditionally. Sorry, crap explanation I know.
I'd go bigger than a zubat if all the work is on the ground, more room for a longer stroke and you can use your body weight to your advantage a lot more. Maybe pick up a mini wedge or two if it's all piled on top of itself.
