17 minutes ago, spudulike said:
I got a cheap Chinese 24 litre compressor a bit like that SGS one for a bargain £45 delivered. Not sure how it happened but it did and 4 years in, it has been brilliant.
A bit noisy but outlasted the Screwfix one that did only 2 years.
One thing to remember, big rattle guns need a big feed pipe, the little coily airline pipe won't feed enough air.
Apart from that, it will power nail and staple guns, pump up tyres and clean chainsaws via an air line. All arb types should have one!!
With the advances in battery tools, air impact wrenches are obsolete.
As regards air flow- yes, bigger hoses are a must, and also the pcl XF quick fittings- which thankfully seem to be standard even on cheap compressors these days.
I’ve got the 50ltr Sgs had it about three years with no issues, good customer service if you ring them , they send them with the euro coupling that was the only pain swapping over the old ones
10 hours ago, Dan Maynard said:
If it's occasional use, I'd get the 25litre 2.5hp. Bigger tank will just mean waiting twice as long after you turn it on before it's up to usable pressure. Go for 2.5hp though because that will fill it up quicker.
I find with mine If you are only pumping up your truck tiers you can use it strait away . Most will go into the tire and some  into the tank. When you have done this a couple of times there is enough in the tank to use an air line to blow out filters etc with out turning it on.
  • 4 weeks later...
I had a cheap Screwfix compressor 24 litres that lasted about 7 years, replaced with a half decent machine mart compressor that the outlet pipes snapped off in the hot weather after about three years. I replaced that with a Hyundai silent compressor for just over £150 and I've been really impressed with it. It's nice to be able to work next to it on saws and be able to hear yourself think....and not jump out of your skin when the motor kicks in 😂
It looks like a bigger version of my £45 24 litre one. It has been pretty much faultless in the 5 years I have had it, run it daily for most of that time. The only thing that failed was a thick rubber diaphragm which was some sort of pressure cut off and got a spare for £10 as it is a generic..."slap your company name on me" type.
Better than the £120 screwfix one I had before.
It is a bit noisy but....£45.....you can easily do that on a meal for two! I still don't know why it was so cheap as it went up to double my price a few days later....probably a mistake....and they delivered it for free:thumbup:
7 hours ago, GarethM said:
Whilst it says 1-2 week back order, why is the whole thing cheaper than just the replacement pump motor that's listed under the listing?.
Well spotted! Most times when things look like a mega deal, they ain't! 🤣
