Hey all.
I am in need of a very small basin for a van I'm Converting.
I'm considering turning a live edged one out of a very old yew log.
See teak one alot quite Cheap but they are always too big.
Any body have an opinion on this?
Also anybody have any crazy ideas for plastic free shower walls?
I have seen a shower done with old school corrugated / wrinkly galvanised roof sheets. Seemed to work quite well.
Yeah I am considering that. Space being a premium though I would prefer something thinner. I did wonder about putting some on some concrete and running a roller over it.
Might try that with a old bit I have and see what happens
5 hours ago, muttley9050 said:
Hey all.
I suppose if you wanted to try to continue a Yew theme you could try lining the shower with waterproof bathroom Yew laminate.
It might need extra sealing once set in place buy could look very nice,
  WWW.GOOGLE.COM
Read more
The average laminate isn't plastic free though
OK, so what's you're aim then, there must be plenty of man made materials in the van already ?
I suppose potentially you could mill thin Yew boards, T&G them and saturate them with setting oil which would waterproof them, but they'd have to be very good boards not to need defects filled with resin.
I've done the above process with platters and at least 8 years down the line and with normal dishwashing they are now needing recoated.. just for surface finish .
My pet hate is grout so I have for a long time clad any shower I'm working on with 1 piece of vinyl flooring made to measure and glued in place with the only joint being the silicone bead where it meets the shower base and sides.
Did it once with 2 one piece Formica sheets which also worked well.
What’s the deal with being plastic free?
Don't want to buy a load of unnecessary plastic, don't like the average plastic shower room in a camper. Feels nasty. Easily damaged
Oh right. OK.
